[Qgis-developer] Drag n drop on OS X
Nyall Dawson nyall.dawson at gmail.com
Mon Jun 8 20:56:51 PDT 2015
On 9 Jun 2015 1:07 pm, "Larry Shaffer" <larrys at dakotacarto.com> wrote:
> Hi,
> This can be fixed for Qt 4.8.x, but requires direct access to the Cocoa
API when needed to introduce the non-Qt-source workarounds noted in the
QTBUG-40449 [0].
> Btw, this is an example of my old PR [1] to introduce abstracted calls to
the OS (Mac for example, with Objective-C++) to handle changes in OS API
libraries and keep such workarounds in one place instead of peppered
throughout the source tree. Especially for those instances where Qt fails
us, but a direct call to the OS could be abstracted for a workaround where
needed.
> Unfortunately, it is a significant change that needs really tested well,
and certainly not reasonable to introduce into 2.10 as a fix, as it is more
of a feature.
> I never upgraded to 10.10 for several reasons, but am about to, or I
would have noticed this nasty bug sooner.
> [0] https://bugreports.qt.io/browse/QTBUG-40449
> [1] https://github.com/qgis/QGIS/pull/1084
Thanks for looking into this Larry,
I'm wondering - is there anything stopping the OSX builds from moving to
the Qt5/pyqt4 combination? I gather qt4 on 10.10 is unsupported and
probably has a lot of little quirks like this we can't easily fix. I'm
tipping the next OSX release will have even more. But since we're not
relying on a distro and are more or less free to choose dependencies on
OSX, couldn't we switch the OSX build across now?
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150609/06c280b6/attachment.html>
