[Qgis-developer] Bug priority for release
Andreas Neumann a.neumann at carto.net
Fri Jun 12 04:13:53 PDT 2015
Hi Paolo,
Half of the blocker tickets are in feedback state. Seems like some users
don't care so much as to response in a reasonable amount of time. Given
that our "dedicated" bug fixing period is rather short, it is crucial
that the users who reported a bug also respond quickly.
regarding
http://hub.qgis.org/issues/12926
Are you aware that there are two modes for loading DB tables? There is
the checkbox "Select at ID". If you uncheck this for large tables it
means that the initial loading is faster, but once you loaded all
features they are cached clientside and should allow for fast scrolling.
Of course this also means more local memory usage.
Note that for slower db-views or slow network connections it is also
recommended to uncheck the "Select at ID" checkbox, so that the table
will be cached locally.
Also: Matthias Kuhn is working on the SQL expression compiler that will
allow serverside filtering. But it won't make it to 2.10. You'd have to
wait for 2.12.
Regarding issue 12578: the new snapping mechanism was implemented by
Martin Dobias - so it would be best, if he could fix the issue.
Hopefully he can do that.
Andreas
On 12.06.2015 11:35, Paolo Cavallini wrote:
> Hi all.
> With 159 tickets classified as High and Blocker, it is quite obvious
> that even with the investment we are doing, many important bugs will be
> left in 2.10.
> Obviously the appointed developers will have the best judgement as to
> what is most efficient in the limited time frame. I respectfully point
> out a couple of serious ones that make working with large (millions of
> records) PG tables almost impossible:
> * http://hub.qgis.org/issues/12578
> * http://hub.qgis.org/issues/12926
> I think we would do a good service to our enterprise users if we can fix
> them. Actually, I'm surprised none of our big users already stepped in:
> maybe I'm missing something?
> All the best, and thanks.
