[Qgis-developer] Bug priority for release
Jürgen E. Fischer jef at norbit.de
Fri Jun 12 06:02:45 PDT 2015
Hi Andreas,
On Fri, 12. Jun 2015 at 13:13:53 +0200, Andreas Neumann wrote:
> http://hub.qgis.org/issues/12926
#12926 is a feature request.
The workaround for this (see 86d08b6c) - until the sql expression are there -
is to set the initial mode for the attribute table to "only visible on map" in
options.  That will request only the features in the current canvas.
Note that this is different from what you can set in the attribute table
itself.  If set in options the attribute table will always be tied to canvas
extent it was opened with - so "show all" within such a table will again only
show the features in the initial canvas extent - "show only visible" will still
have an effect if you zoom in.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150612/c334e62b/attachment-0001.pgp>
