[Qgis-developer] Crash in new GRASS plugin?
Radim Blazek radim.blazek at gmail.com
Mon Jun 22 23:04:53 PDT 2015
On Thu, May 21, 2015 at 10:53 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Thu, May 21, 2015 at 10:27 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>>> AFAICT, it can only happen if you have GISRC set, but the file does
>>> not exist or it is corrupted. Try to unset GISRC envar and it should
>>> run.
>> I think this is due to Processing, that sets temp grass variables.
> I see:
> algs/grass/GrassUtils.py 250: os.putenv('GISRC', gisrc)
> I think that Processing should not set GISRC globally, it should
> rather start modules with that envar. QGIS may be started from GRASS
> shell, in that case the plugin is using GISRC to setup active mapset
> so it must not be changed. The plugin is also setting GISRC globally
> when a mapset is opened, but that is correct, because it also locks
> the mapset and in that case it works like a GRASS shell.
> Victor, could you please remove
>   os.putenv('GRASS_MESSAGE_FORMAT', 'gui')
>   os.putenv('GRASS_BATCH_JOB'...
> is not it enough to set them in createGrassScript()?
Victor, can you look at it please?
Radim
