[Qgis-developer] 2.5D rendering crowdfunding
Nyall Dawson nyall.dawson at gmail.com
Thu Nov 5 11:31:14 PST 2015
On 6 Nov 2015 06:16, "Hugo Mercier" <hugo.mercier at oslandia.com> wrote:
> On 05/11/2015 19:10, Matthias Kuhn wrote:
> > On 11/05/2015 05:07 PM, Hugo Mercier wrote:
> >> Correct.
> >> A first step where the additional geometry columns are considered to be
> >> expressed in the same CRS as the main geometry column would already be
> >> interesting.
> >> And yes, that would be better if additional geometries could be
accessed
> >> directly as QgsGeometry, and converted to WKT only when needed
> >> (attribute table ?). It's probably only modifications provider-side.
> > The conversion provider side are probably straightforward (just use the
> > code that is used to create the main geometry of the feature).
I've got a partial implementation of this I tried a while back. I'll dig it
up and see if it's of any use.
Nyall
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151106/4e86c884/attachment.html>
