[Qgis-developer] New GRASS plugin: a test drive
Paolo Cavallini cavallini at faunalia.it
Mon Oct 5 05:58:20 PDT 2015
Il 05/10/2015 14:44, Radim Blazek ha scritto:
> On Sat, Oct 3, 2015 at 8:02 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>> * G6 vectors are shown with a red cross,
> And the name is followed by "topology version 6", right?
exactly
> What do you suggest? My idea was "Build topology" item in context
> menu. But we are over feature freeze and if somebody has already G6
> vectors, he should know that he must rebuild topology in G7. It is
> described here:
> https://grasswiki.osgeo.org/wiki/Convert_all_GRASS_6_vector_maps_to_GRASS_7
I think the context menu is fine, and adding it should not be an issue
now (I could say not being able to readily use my data is a bug, and
your suggestion fixes it).
> I fixed the crash and removed new layer menu items from the vector if
> it is not valid.
great, thanks
>> * I created a new polygon layer, but it is unclear to me how to add objects
> Draw features? There should be usual Add Point, Add Line etc. tools in
> Digitizing Toolbar.
yes - I tried, but the newly added polygon etc is not displayed once
digitized. Oh, now I see: the custom grass symbology prevents me from
seeing it. Once moved to single symbol, it is displayed.
>> * if I remove a raster which is already loaded in the canvas, I get a
>> warning (empty, grey dialog) and QGIS is stuck (I had to force close it)
> Fixed, it was trying to show a warning from rendering non GUI thread.
thanks again
>> * loaded rasters display a legend, but not the labels.
> Labels were never supported, you can fill feature request issue.
done: https://hub.qgis.org/issues/13518
>> Otherwise, great stuff!
>> Should I open tickets for all this?
> No, except for color labels. For now, if you find more issues, write
> it here and I'll try to fix immediately.
ok, thanks
> Very welcome. There are still issues in editing, that is why I have
> not announced yet the upgrade to be finished. The implementation of
> editing became incredibly complex. Basic editing should mostly work
> however.
I can imagine. Where do I find a guide on how to digitize? I tried
adding polygon, then centroid, but I only ended up with an invisible
geom. I'm certainly missing something here.
All the best, and thanks again.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
