[Qgis-developer] Processing: return table from PostGIS query
Victor Olaya volayaf at gmail.com
Fri Oct 9 03:48:15 PDT 2015
No that was not my intention. I don't mind if it depends on another
core plugin, that is actually good
If I remember right, I reused that lib because it was also part of
core or of some other plugin, and I found the DB manager architecture
to be more complex and not inmediate for being used as a lib. But yes,
I guess all can be done as well with the DB manager classes
I wouldn't be against it if someone wants to modify the algorithms
that use postgis_utils and use DB manager code instead, so we can get
rid of a library and not have redundant code...
Cheers!
2015-10-09 9:31 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi Spencer,
> When I created these script, I think the postgis_utils did not exist yet (or
> I just did not know about it). And I thought all the work around Databases
> was focused on DBManager to avoid redundacy.
> We should ask Victor about it. Perhaps Victor did not want processing to
> depend on another plugin ?
> Cheers
> Michaƫl
> 2015-10-08 20:45 GMT+02:00 Spencer Gardner <spencergardner at gmail.com>:
>> Brilliant. I wasn't aware that it was so easy to use DB Manager from
>> Python. Up to now I've been connecting to my PostGIS database using the
>> postgis_utils included with Processing.
>> So this begs the question: what is the use of postgis_utils if the same
>> functionality is achieved through DB Manager?
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
