[Qgis-developer] Processing: return table from PostGIS query
kimaidou kimaidou at gmail.com
Sat Oct 10 07:34:59 PDT 2015
Hi Victor,
Thanks for your answer.
Using the db_manager tools has an advantage : you can interact with
Spatialie and Oracle too.
I have no time at the moment to have a look at it, but I will write back
here whenever I have some.
We should first make sure which plugin or algorithm uses it, and see if
this can be changed.
Cheers
Michaël
2015-10-09 12:48 GMT+02:00 Victor Olaya <volayaf at gmail.com>:
> No that was not my intention. I don't mind if it depends on another
> core plugin, that is actually good
> If I remember right, I reused that lib because it was also part of
> core or of some other plugin, and I found the DB manager architecture
> to be more complex and not inmediate for being used as a lib. But yes,
> I guess all can be done as well with the DB manager classes
> I wouldn't be against it if someone wants to modify the algorithms
> that use postgis_utils and use DB manager code instead, so we can get
> rid of a library and not have redundant code...
> Cheers!
> 2015-10-09 9:31 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> > Hi Spencer,
> > When I created these script, I think the postgis_utils did not exist yet
> (or
> > I just did not know about it). And I thought all the work around
> Databases
> > was focused on DBManager to avoid redundacy.
> > We should ask Victor about it. Perhaps Victor did not want processing to
> > depend on another plugin ?
> > Cheers
> > Michaël
> > 2015-10-08 20:45 GMT+02:00 Spencer Gardner <spencergardner at gmail.com>:
> >> Brilliant. I wasn't aware that it was so easy to use DB Manager from
> >> Python. Up to now I've been connecting to my PostGIS database using the
> >> postgis_utils included with Processing.
> >> So this begs the question: what is the use of postgis_utils if the same
> >> functionality is achieved through DB Manager?
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151010/20d4f8e3/attachment.html>
