[Qgis-developer] New GRASS plugin: a test drive
m roy royroge at outlook.com
Mon Oct 12 10:45:47 PDT 2015
Il 12/10/2015 19.32, Radim Blazek ha scritto:
> On Mon, Oct 12, 2015 at 6:33 PM, m roy <royroge at outlook.com> wrote:
>>>> another issue I discovered while testing QGIS digitizer with GRASS vectors
>>>> is that there is no difference between node and vertex, in GRASS they have
>>>> two different "topological meaning"; as it is now you can't tell
>>>> where to connect with a new boundary because of this.
>>> I think that the cleanest way to get nodes displayed will be to add
>>> first/last vertex marker line symbol in boundaries style, which you
>>> can try immediately if you change 'GRASS Edit' style.
>> Nice idea, just tried, unfortunately QGIS crashes (on Windows) if i try
>> to change line
>> boundary to "Marker line";
> With 'GRASS Edit' style only? When exactly? When you click Apply on style tab?
> Radim
QGIS crashes when you select "Marker line" in symbol layer type right away,
not only with 'GRASS Edit' style also with default style on a shapefile; so
i think it's not related to GRASS plugin...
