[Qgis-developer] New GRASS plugin: a test drive
Radim Blazek radim.blazek at gmail.com
Mon Oct 12 10:57:48 PDT 2015
On Mon, Oct 12, 2015 at 7:45 PM, m roy <royroge at outlook.com> wrote:
> Il 12/10/2015 19.32, Radim Blazek ha scritto:
>> On Mon, Oct 12, 2015 at 6:33 PM, m roy <royroge at outlook.com> wrote:
>>>>> another issue I discovered while testing QGIS digitizer with GRASS vectors
>>>>> is that there is no difference between node and vertex, in GRASS they have
>>>>> two different "topological meaning"; as it is now you can't tell
>>>>> where to connect with a new boundary because of this.
>>>> I think that the cleanest way to get nodes displayed will be to add
>>>> first/last vertex marker line symbol in boundaries style, which you
>>>> can try immediately if you change 'GRASS Edit' style.
>>> Nice idea, just tried, unfortunately QGIS crashes (on Windows) if i try
>>> to change line
>>> boundary to "Marker line";
>> With 'GRASS Edit' style only? When exactly? When you click Apply on style tab?
> QGIS crashes when you select "Marker line" in symbol layer type right away,
> not only with 'GRASS Edit' style also with default style on a shapefile; so
> i think it's not related to GRASS plugin...
Please fill a new issue in bug tracker and mark it blocker.
Radim
