[Qgis-developer] GDAL 2.1 can update Geojson files - What is missing in QGIS to edit GeoJSON files ?
Even Rouault even.rouault at spatialys.com
Thu Jan 14 07:44:05 PST 2016
Hi Michael,
> I have read that GDAL can now update GeoJSON  since version 2.1.0. See [1]
> If I build QGIS with GDAL 2.1, would I be able to edit the GeoJSON as I can
> for Shapefiles ?
Yes, that was developed mostly for the QGIS use case and has been tested with
it. You have full editing capabilities : adding, deleting, modifying features,
adding, deleting fields.
> Another GeoJSON related question. Any idea on the relevance of adding the
> ability to create a spatial index file *.qix for GeoJSON layers in order to
> improve rendering speed ?
The OGR GeoJSON driver proceeds into the ingestion of the full file into
memory, which can be a limitation when dealing with huge files ( the json-c lib
might typically consume an amount of memory more than 10 times the size of the
geojson file).
For a in-memory layer like the one used underneath by the GeoJSON driver, the
spatial filtering done by OGR uses a basic BBOX filter while iterating over the
features (the BBOX isn't stored into the geometry object but recomputed each
time it is needed). This could potentially benefit from a in-memory spatial
index, but I'd expect that to be only useful for large geojson files (let's say
> 100 MB), i.e. the ones that the driver would currently have issues to deal
with.
A more "streaming-like" approach for the driver not proceeding to full
ingestion of features could be desirable to remove that limitation, but that's
more involved. A possibility could be to have a "at-hand" parser to delimitate
JSon "Feature" objects and use only json-c to parse each feature. But GeoJSON
is certainly not the more appropriate file format to deal with huge datasets...
Cheers,
Even
http://www.spatialys.com
