[Qgis-developer] Processing provider versions and hard coded path in settings
Alexander Bruy alexander.bruy at gmail.com
Mon Jan 25 03:12:32 PST 2016
Hi Stefan,
Processing providers are just plugins, so they installed in the global
QGIS plugins
directory. There is no hadrcoding in Processing sources related to the
providers.
2016-01-25 12:04 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> Dear devs,
> In my QGIS.ini, the paths to the Processing providers are hard coded, which
> means I have to manually adjust them after every software update (Saga,
> GRASS, R).
> Any chance to pass the updates to the user(s)`s QGIS settings (or make QGIS
> recognizing the Processing providers installed together with QGIS), or is
> this only a limitation of the --configpath solution?.
> Should I extend:
> http://hub.qgis.org/issues/12623
> (as it seems related) or should I open a new ticket (in case this wanted and
> feasible of course)...
> Kind regards,
> Stefan
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
