[Qgis-developer] adding SAGA algorithms in Processing
matteo
matteo.ghetta at gmail.com
Mon Jun 20 00:19:12 PDT 2016
Hi all,
I'm trying to add some missing SAGA algorithm in Processing.
I saw that the addition is a simple txt file with some parameter:
* name of the SAGA alg (the extact name)
* name of the Processing group in which the alg will be added in Processing
* all the parameters divided by pipes
e.g. the aggregate algorithm is:
Aggregate
grid_tools
ParameterRaster|INPUT|Grid|False
ParameterNumber|SIZE|Aggregation Size|None|None|3
ParameterSelection|METHOD|Method|[0] Sum;[1] Min;[2] Max
there are many interesting SAGA algorithms that can be added but I
encounter some difficulties with the parameter (names, type,
default....) even with SAGA standalone opened so I can compare all of them.
I tried to add the SAGA Transpose Table like (and it works):
Transpose Table
table_tools
ParameterTable|INPUT|Input|False
OutputTable|OUTPUT|Output
for more complex algorithms I had a look in existing ones but still it
is not straightforward.
I'm wondering if somewhere there is some existing documentation and/or
if it is worth to add just some basic guidelines.
Thanks to all
Matteo
