[Qgis-developer] adding SAGA algorithms in Processing
Victor Olaya volayaf at gmail.com
Mon Jun 20 00:49:39 PDT 2016
In the grass folder of processing there is a file explaining the
syntax, for GRASS algorithm. It is the same syntax for SAGA, so you
can follow that doc
2016-06-20 9:19 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hi all,
> I'm trying to add some missing SAGA algorithm in Processing.
> I saw that the addition is a simple txt file with some parameter:
> * name of the SAGA alg (the extact name)
> * name of the Processing group in which the alg will be added in Processing
> * all the parameters divided by pipes
> e.g. the aggregate algorithm is:
> Aggregate
> grid_tools
> ParameterRaster|INPUT|Grid|False
> ParameterNumber|SIZE|Aggregation Size|None|None|3
> ParameterSelection|METHOD|Method|[0] Sum;[1] Min;[2] Max
> there are many interesting SAGA algorithms that can be added but I encounter
> some difficulties with the parameter (names, type, default....) even with
> SAGA standalone opened so I can compare all of them.
> I tried to add the SAGA Transpose Table like (and it works):
> Transpose Table
> table_tools
> ParameterTable|INPUT|Input|False
> OutputTable|OUTPUT|Output
> for more complex algorithms I had a look in existing ones but still it is
> not straightforward.
> I'm wondering if somewhere there is some existing documentation and/or if it
> is worth to add just some basic guidelines.
> Thanks to all
> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
