[Qgis-developer] Symbology export in save as feature
Yves Jacolin yjacolin at free.fr
Fri Jun 24 05:17:23 PDT 2016
Andreas,
Thanks for you explenation. I added some of your description in the
documentation.
Y.
On Friday, June 24, 2016 11:15:45 Neumann, Andreas wrote:
> Hi Yves,
> This has mainly "historic" reasons.
> It was introduced specifically when saving QGIS layers to DXF through
> OGR. I believe also the KML export is affected to some extent.
> Our first attempt to export QGIS layer to DXF went through OGR with OGR
> feature  - however, this was too limited, and it was abandoned.
> "No symbology" means, simple black default lines
> "Feature symbology" means "Save with OGR Feature Styles"
> "Symbol Layer symbology" means "Save with OGR Feature Styles but export
> the same geometry multiple times if there are multiple symbology symbol
> layers used"
> Meanwhile the DXF export from QGIS goes through a native DXF writer -
> without OGR, so the above approach was abandoned and hasn't been worked
> on for some years now.
> I hope this explains what it does, but as I said it is limited for
> export to DXF/KML or potentially formats that support OGR feature styles
> - formats that can handle styles.
> For QGIS 3.0 I see the following ways to get rid of this:
> 1. keep it but improve it (unlikely)
> 2. hide it for layers that don't support OGR feature styles (can be
> combined with 1.)
> 3. get rid of it completely (my preferred option if 1. does not happen)
> BTW: 2. could probably be done for QGIS 2.16 and 2.14 already, to have
> fewer confused users ...
> Hope this explains it.
> What do others think?
> Andreas
> On 2016-06-24 10:43, Yves Jacolin wrote
> > Hello,
> > Working in the "save as ..." feature documentation I wondering what
> > "Symbology export" parameters mean. There are 3 possibilities: "No
> > symbology", "Feature symbology" and "Symbol layer symbology".
> > Any idea what does it mean?
> > Thanks,
> > Y.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
