[Qgis-developer] Questions/Suggestion on virtual layers
Neumann, Andreas a.neumann at carto.net
Wed Mar 2 08:29:12 PST 2016
Hi Yves,
On 2016-03-02 17:20, Yves Jacolin wrote:
> Andreas,
> In the layer toolbar, after the "Add a delimited text Layer" icon you have the
> "Add a virtual layer" tools. In the panel you can choose a virtual layer name.
> If you create two virtual layer, when you come back to this windows, the
> dropdown list will show you the two layers that you can edit.
Ah - now I see what you mean. Thanks - so with this drop-down box I can
access the definitions of all the existing virtual layers in the
project. Nice.
The only usability problem is that you have to go throuhg "Add a new
virtual layer" in order to edit the definition of an existing one. I
think this is quite confusing.
> But you are right, if there is an error, the virtual layer won't be saved.
Well - if we had a preview of the results - this wouldn't be much of an
issue. I can understand that virtual layers with an error in the
definition shouldn't be saveable.
Thanks,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160302/c179e0f2/attachment-0001.html>
