[Qgis-developer] BUG? strpos("area",'.') doesn't work
Mathieu Pellerin nirvn.asia at gmail.com
Mon Nov 7 03:26:04 PST 2016
We should indicate in the function help that strpos is regexp based.
On Nov 7, 2016 6:23 PM, "Matthias Kuhn" <matthias at opengis.ch> wrote:
> Hi,
> strpos is based on regexp, a '.' matches any character.
> To let the engine treat a . as such you need to prefix it with a
> double-backslash.
> strpos(to_string("area"), '\\.')
> Regards
> Matthias
> On 11/07/2016 12:07 PM, Elstermann, Mike wrote:
> > Hi,
> > “area” is a double-field with values e. g. 213.1234,  43215.3456, …
> > strpos("area",'.') gives only value 1 return :-(
> > strpos(to_string("area"),'.') gives only value 1 return  :-(
> > This error exits only by ‘.’, other search-strings e. g. ‘12’, ‘1’, …
> > work fine
> > Our workarround works fine.
> > strpos( replace( to_string( "area" ), '.', ',' ), ',' )
> > Is this a bug with ‘.’?
> > best regards, mikeE.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161107/c11bee99/attachment.html>
