[Qgis-developer] BUG? strpos("area",'.') doesn't work
Matthias Kuhn matthias at opengis.ch
Mon Nov 7 03:39:58 PST 2016
I wonder if we should change this for QGIS 3.0 and use QString::indexOf
instead, while providing dedicated regexp functions.
What do you think, Mathieu?
Matthias
On 11/07/2016 12:26 PM, Mathieu Pellerin wrote:
> We should indicate in the function help that strpos is regexp based.
> On Nov 7, 2016 6:23 PM, "Matthias Kuhn" <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Hi,
>     strpos is based on regexp, a '.' matches any character.
>     To let the engine treat a . as such you need to prefix it with a
>     double-backslash.
>     strpos(to_string("area"), '\\.')
>     Regards
>     Matthias
>     On 11/07/2016 12:07 PM, Elstermann, Mike wrote:
>     > Hi,
>     > “area” is a double-field with values e. g. 213.1234,  43215.3456, …
>     > strpos("area",'.') gives only value 1 return :-(
>     > strpos(to_string("area"),'.') gives only value 1 return  :-(
>     > This error exits only by ‘.’, other search-strings e. g. ‘12’, ‘1’, …
>     > work fine
>     > Our workarround works fine.
>     > strpos( replace( to_string( "area" ), '.', ',' ), ',' )
>     > Is this a bug with ‘.’?
>     > best regards, mikeE.
>     > _______________________________________________
>     > Qgis-developer mailing list
>     > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     > Unsubscribe:
>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
