[Qgis-developer] Access violation - no RTTI data
Matthias Kuhn matthias at opengis.ch
Mon Oct 17 01:24:55 PDT 2016
Hi Tom,
RTTI is some low-level C++ functionality to determine an objects type
(roughly equivalent to `type(myobject)` in python). It can be enabled
and disabled during compilation. Apparently it was disabled on your QGIS
build.
The bad news: QGIS uses this information to determine which type of
symbollayer is in use.
The good news: This can be fixed, I've just fixed it in master [1].
Please let me know if you need this backported and where to (so you can
test).
Matthias
[1]
https://github.com/qgis/QGIS/commit/8fa3127c66220ad338ea9a1b367b0d78c56c9067
On 10/16/2016 01:14 PM, Tom Chadwin wrote:
> So RTTI is info about object data types at runtime? Is the print unable to
> determine the symbollayer or symbollayerlist (or whatever the latter is)
> type? Why?
> Obviously, my aim is not to print, but to use the data. However, the error
> occurred before I used print to investigate the problem.
> Can anyone help?
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Access-violation-no-RTTI-data-tp5290830p5290885.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
