[Qgis-developer] Access violation - no RTTI data
Nyall Dawson nyall.dawson at gmail.com
Mon Oct 17 01:28:39 PDT 2016
On 17 October 2016 at 18:24, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Tom,
> RTTI is some low-level C++ functionality to determine an objects type
> (roughly equivalent to `type(myobject)` in python). It can be enabled
> and disabled during compilation. Apparently it was disabled on your QGIS
> build.
Wouldn't that cause a ton of other errors though? It's used pretty
heavily all throughout QGIS, and there's many other sip classes
relying on it...
Nyall
> The bad news: QGIS uses this information to determine which type of
> symbollayer is in use.
> The good news: This can be fixed, I've just fixed it in master [1].
> Please let me know if you need this backported and where to (so you can
> test).
> Matthias
> [1]
> https://github.com/qgis/QGIS/commit/8fa3127c66220ad338ea9a1b367b0d78c56c9067
> On 10/16/2016 01:14 PM, Tom Chadwin wrote:
>> So RTTI is info about object data types at runtime? Is the print unable to
>> determine the symbollayer or symbollayerlist (or whatever the latter is)
>> type? Why?
>> Obviously, my aim is not to print, but to use the data. However, the error
>> occurred before I used print to investigate the problem.
>> Can anyone help?
>> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
>> View this message in context: http://osgeo-org.1560.x6.nabble.com/Access-violation-no-RTTI-data-tp5290830p5290885.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
