[Qgis-developer] Plans for next QGIS releases
DelazJ delazj at gmail.com
Sat Apr 1 23:59:44 PDT 2017
Hi Jürgen,
Thanks for the fix and explanation.
Regards,
Harrissou
Le samedi 1 avril 2017, Jürgen E. Fischer <jef at norbit.de> a écrit :
> Hi Harrissou,
> On Fri, 31. Mar 2017 at 21:53:33 +0200, DelazJ wrote:
>> #. 3.0 will be a LTR (actually from 3.0.9 - nine months after first
>> release?)
> No, 3.2.0 will be the LTR.
>> #. 3.0 will be LTR for *4 months*, replaced by 3.2
> There's a four month overlap where a LTR is also the current LR.  For
that time
> it doesn't replace the old release in the LTR repositories.
> 3.0 in the LTR column is indeed wrong - that should have been more 2.18
point
> releases - fixed.
> I also switched the LTR and LR columns as the event refers primarily to
the LR
> column (maybe a source of confusion).
>> - I fail to understand the reason why once 3.0 is released, we continue
to
>>   break our "four-months release" policy.
> That's what we discussed - more time to stablize 3.x before it goes LTR.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
+49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
+49-4931-918175-50
> Software Engineer           D-26506 Norden
http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on
FreeNode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170402/8589b650/attachment.html>
