[Qgis-developer] Are there plans to create a unique "Add layer" tool?
Stéphane Henriod stephanebek at gmail.com
Tue Apr 4 03:58:43 PDT 2017
Thanks Nyall!
Here I just created a Gdoc to collect info mentioned in your points 1-4 + a:
https://docs.google.com/document/d/1aMX9jOfl10q8oETRzOHSHnRpHCc7UJ1dDnCCq3VyTAY/edit?usp=sharing
All interested, feel free to contribute, I might not have the full overview
Thanks and cheers
Stéphane
“When you travel, remember that a foreign country is not designed to make
you comfortable. It is designed to make its own people comfortable." --
Clifton Fadiman
2017-04-04 13:53 GMT+06:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 4 April 2017 at 17:46, Stéphane Henriod <stephanebek at gmail.com> wrote:
> > Thanks a lot Anita for the info!
> > I re-located the issue: http://hub.qgis.org/issues/9451
> > Not sure though if this will make it alive again. Let's see if this
> seems to
> > be a priority for enough users...
> I'd say a good plan to move this forward would be to:
> 1. conduct a thorough survey of what's available via the individual
> add vector layer dialogs vs what's currently available in the browser
> 2. rank each of the missing settings vs whether or not they are still
> required
> 3. file issues for these missing settings
> 4. ...and get these fixed/implemented
> a. While this is underway I'd also suggest the UX team could test and
> evaluate Anita's plugin to identify whether the browser alone is a
> sufficient replacement or whether some tweaks would be required to
> make it a suitable replacement without any loss of "user friendliness"
> 1,2,3 and (a) don't require any development experience, so would be a
> great project for any interested user to undertake. I suspect 4
> wouldn't be much work for a developer either after all this groundwork
> is done.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170404/66b7c88f/attachment-0001.html>
