[Qgis-developer] Set processing input default value to layer custom property
Ari Jolma ari.jolma at gmail.com
Tue Apr 11 02:10:16 PDT 2017
11.04.2017, 11:50, Tom Chadwin kirjoitti:
> Hi Ari
> What a great idea. Thank you. I guess the one downside is that it means the
> main algorithm will not function on its own, so you have to rely on
> documentation to inform the user not to try to use it without your
> preprocessor?
By main algorithm you mean what? For the user the model appears similar
to any algorithm, although it is made of many algorithms (that's the
case for all QGIS processing models). Each work on their own with
correct input. You can study the model here
https://github.com/ajolma/SmartSeaMSPTool/tree/master/processing_models
Ari
> Thanks again
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Set-processing-input-default-value-to-layer-custom-property-tp5316416p5316800.html
> Sent from the QGIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
