[Qgis-developer] PostGIS Rasters
Jorge Gustavo Rocha jgr at di.uminho.pt
Tue Apr 11 02:23:38 PDT 2017
Hi Andreas,
The QGIS performance reading rasters from Postgis is not so bad, if
pyramids are available on the database. QGIS takes advantage of the
pyramids, if they exist. Check [1].
Regards,
Jorge
[1]
http://gis.stackexchange.com/questions/151632/poor-performance-with-storing-large-rasters-in-postgis-and-visualising-in-qgis/227324#227324
Às 06:56 de 11-04-2017, Neumann, Andreas escreveu:
> Hi,
> If there will be a new Postgis raster provider for QGIS, it should also
> support the pyramid tables (separate tables) - which as far as I know -
> is not yet supported. If you add a layer from DB-manager you load a
> fixed resolution and the other pyramid tables won't be used. Thats one
> of the reasons, rasters in Postgis display quite slow in QGIS.
> Andreas
> On 2017-04-11 04:16, Robert Hewlett wrote:
>> Hi,
>> Are there plans to build a plugin for PostGIS rasters similar to the
>> vector plugin. I know how to add the rasters from the DB manager but
>> the experience/workflow is much different and the connections go 'stale'.
>> I am willing to help code it.
>> Regards,
>> Rob
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
