[Qgis-developer] DWG/DXF Import -- Geopackage
Stéphane Henriod stephanebek at gmail.com
Mon Apr 17 01:37:25 PDT 2017
Ok, thanks for the clarification!
Then I guess that the window should be re-designed a bit. To me at least it
was not intuitive that "Geopackage" has to do with the output of the tool.
And yes, maybe both "DXF Export" and "DWG/DXF import" could be moved
somewhere else?
Cheers
Stéphane
Le lundi 17 avril 2017, Tudor Barascu <tudorbarascu at yahoo.com> a écrit :
> Hi Stephane,
> That button is for importing DWG/DXF. It does the import into a Geopackage.
> Don't know why it's stored under "Project"
> All the best,
> Tudor
> On Monday, April 17, 2017 8:02 AM, Stéphane Henriod <stephanebek at gmail.com
> <javascript:_e(%7B%7D,'cvml','stephanebek at gmail.com');>> wrote:
> Hi all
> while updating the doc to describe a future unique "Add data" button
> https://docs.google.com/document/d/1aMX9jOfl10q8oETRzOHSHnRpHCc7U
> J1dDnCCq3VyTAY/edit?usp=sharing I stumbled upon the *Project / DWG/DXF
> Import*.
> 2 questions here:
>    - Is there a reason why this import tool is stored under "Project"?
>    Doesn't seem consistent to me but maybe I am missing a point
>    - It's quite confusing that the menu is called "DWG/DXF" while it is
>    actually here to import Geopackage layers
> Also, when trying to import this sample dataset http://www.geopackage.org/
> data/gdal_sample_v1.2_no_extensions.gpkg I get an error "Could not open
> layer list", although all goes well if I drag-and-drop from the browser.
> Not sure if I should open a bug report or if this is all being taken care
> of already?
> Cheers
> Stéphane
> “When you travel, remember that a foreign country is not designed to make
> you comfortable. It is designed to make its own people comfortable." --
> Clifton Fadiman
> Qgis-developer mailing list
> <javascript:_e(%7B%7D,'cvml','Qgis-developer at lists.osgeo.org');>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Clifton Fadiman
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170417/4691700d/attachment.html>
