[QGIS-Developer] [Qgis-user] QGIS 2.18.11 - Problem with SAGA installation: unsupported SAGA version found.
Johan Van de Wauw johan.vandewauw at gmail.com
Tue Aug 8 02:01:08 PDT 2017
Other than 2.3.x to be correct (the others (2.3.0 /2.3.1 ) should work as well)
On Tue, Aug 8, 2017 at 7:26 AM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hi Calvin,
> Due to frequent changes in SAGA algorithms, that forced frequent updates to
> processing, it was decided to only support SAGA's long-term release. So, if
> you a version of SAGA other than 2.3.2, that might be the problem.
> Alexandre Neto
> A seg, 7/08/2017, 21:14, C Hamilton <adenaculture at gmail.com> escreveu:
>> I realized that the SAGA routines were not showing up in the processing
>> tool box of the OSGeo4W 64 Windows QGIS 2.18.11 installation. The Processing
>> message is:
>> Anyone else have this problem?
>> Thanks,
>> Calvin
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
