[QGIS-Developer] Attribute table - item not highlighted in form mode when using drag&drop designer
DelazJ delazj at gmail.com
Tue Aug 8 08:31:57 PDT 2017
Hi Michaël,
I can't confirm here (2.18.11, win10) but I think your screenshot says all.
The background color should appear under the feature whose attributes are
displayed on the right.
I would also like to observe that another thing weird in the screenshot is
the count of selected features at the top of the customized form dialog
showing 0 while there's obviously a selected feature (yellow square).
Might not be related but worth mentioning.
Regards,
Harrissou
2017-08-08 14:46 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi all,
> A user reported an issue on QGIS 2.18.11 (and probably previous versions).
> When the drag and drop designer is used for a vector layer, the attribute
> table, viewed in form mode, does not show any colour underneath the current
> feature.
> See this image
> https://framapic.org/Ft1j3xwqga2D/8ARZc3qUL6AP.jpg
> Is is a known issue ? I will obvioulsy open a ticket if needed.
> Regards
> Michaël
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170808/eb7b7a80/attachment.html>
More information about the QGIS-Developer mailing list
