[QGIS-Developer] Python error in processing on 2.99 startup
Tim Sutton tim at kartoza.com
Fri Dec 1 15:10:02 PST 2017
Hi
> On 01 Dec 2017, at 17:30, Gary Sherman <gsherman at geoapt.com> wrote:
> Is this part of the same issue (latest Master build 19b062c):
> 2017-12-01T06:25:26	CRITICAL	Could not open GRASS GIS 7 algorithm: /Users/gsherman/apps/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/algs/grass7/description/r.sim.sediment.txt
> QgsProcessingParameterVectorLayer|observation|Sampling locations vector points|None|True
> 2017-12-01T06:25:26	CRITICAL	Could not open GRASS GIS 7 algorithm: r.sim.sediment.txt
> 'NoneType' object has no attribute 'split'
> 2017-12-01T06:25:26	CRITICAL	Could not open GRASS GIS 7 algorithm: /Users/gsherman/apps/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/algs/grass7/description/r.sim.water.txt
> 2017-12-01T06:25:26	CRITICAL	Could not open GRASS GIS 7 algorithm: r.sim.water.txt
> 2017-12-01T06:25:28	CRITICAL	Problem with SAGA installation: unsupported SAGA version found.
> Running any GRASS alg fails and the dialog closes before you can see any output.
I dont get the specific errors you list above, but I have the same issue you have when trying to run a grass alg….
Regards
Tim
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171202/00623247/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171202/00623247/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
