[QGIS-Developer] How to build QGIS 2.99 with 3D?
Patrick Dunford enzedrailmaps at gmail.com
Tue Dec 5 10:40:16 PST 2017
Oh it might be the prequisite packages for the build environment, these
usually are the ones that are listed in the INSTALL file.
On 06/12/17 06:35, DelazJ wrote:
> Hi,
> Maybe I miss something but I fail to fully understand the link between
> Matteo needs and your explanation, Patrick. it doesn't look like
> Matteo has issues to build QGIS. He already does it, he compiles from
> source himself ( master or any other branch).
> What he wants is simply a way to build QGIS with 3D enabled, thing
> that by default requires an upgraded version of QT (and not available
> in even known and supported distro like Ubuntu 16.04). Unless I
> misunderstood...
> Btw, which key package is missing in Xenial since january? I also do
> build with Xenial and never felt that i'm missing some key features
> (except 3D but i chose to not upgrade for that - worried to break a
> working environment)
> Matteo, have you seen the link I sent earlier
> (https://www.lutraconsulting.co.uk/blog/2017/08/06/qgis3d-build/
> <https://www.lutraconsulting.co.uk/blog/2017/08/06/qgis3d-build/>)?
> Looks like there's a way to have two versions of qt and build
> different QGIS depending on what's enabled....
> Harrissou
> 2017-12-05 17:55 GMT+01:00 Patrick Dunford <enzedrailmaps at gmail.com
> <mailto:enzedrailmaps at gmail.com>>:
>     It's a known issue that Ubuntu Xenial by itself does not include a
>     required version of a key package that is needed by masters later
>     than about January 2017. Attempting to build without this package
>     will presumably fail. This is why Ubuntugis based versions of Qgis
>     are needed to install on Xenial or supported earlier editions of
>     Ubuntu.
>     However as per my other comment it is possible the Mint developers
>     have updated this package in Mint. We have no way of predicting
>     this without in depth knowledge of the distro.
>     On 06/12/17 02:38, matteo wrote:
>         Hi Patrick,
>         thanks for the clarification. Actually I don't have any external
>         repository activated because I'm building QGIS from scratch
>         and I never
>         had to add external sources.
>         Eventually, by activating the nightly repository Qt should be
>         upgradable
>         to the last version required for 3D?
>         Thanks a lot
>         Matteo
>         _______________________________________________
>         QGIS-Developer mailing list
>         QGIS-Developer at lists.osgeo.org
>         <mailto:QGIS-Developer at lists.osgeo.org>
>         List info:
>         https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>         Unsubscribe:
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171206/f6486023/attachment-0001.html>
More information about the QGIS-Developer mailing list
