[QGIS-Developer] What changed on Travis?
Denis Rouzaud denis.rouzaud at gmail.com
Wed Dec 13 17:11:19 PST 2017
I think that the dependency docker image got updated with latest gdal
version (possibly other libs as well) due to Qt Script removal (which
updated the Dockerfile,  hence the image).
Denis
Le mer. 13 déc. 2017 à 18:47, Even Rouault <even.rouault at spatialys.com> a
écrit :
> On jeudi 14 décembre 2017 08:25:31 CET Nyall Dawson wrote:
> > Hi all,
> > Anyone know what changed on Travis yesterday? All of a sudden we're
> > seeing a shapefile test failing with no changes which account for
> > this.
> Nyall,
> I have had today issues on Travis GDAL too (new warnings popping up
> whereas the code was unchanged), and finally tracked that down to an
> upgrade of the Trusty image from clang 3.9 to clang 5.0
> But in the QGIS case, this is weird since according to the cmake report it
> seems to use a clang 3.8 in both cases (probably coming from the docker
> image)
> But this seems definitely correlated with the change of the Travis image
> since the last good build (
> https://api.travis-ci.org/v3/job/315460942/log.txt ) is with the old
> image (with clang 3.9), and the first bad one
> ( https://api.travis-ci.org/v3/job/315604790/log.txt ) is with the new
> image (with clang 5.0)
> I see they've pubished a blog post about the change:
> https://blog.travis-ci.com/2017-12-12-new-trusty-images-q4-launch
> and the updated packages:
> https://docs.travis-ci.com/user/build-environment-updates/2017-12-12/
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171214/216c914a/attachment-0001.html>
More information about the QGIS-Developer mailing list
