[Qgis-developer] Building for Windows 10
Andrew Gillett
arganoid at pair.com
Mon Feb 6 03:28:35 PST 2017
Following the instructions here:
https://htmlpreview.github.io/?https://github.com/qgis/QGIS/blob/master/doc/INSTALL.html
I'm getting the following trying to configure 2.18:
CMake Error: The following variables are used in this project, but they
are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the
CMake files:
PYTHON_LIBRARY
linked by target "qgispython" in directory C:/CodingX/QGIS/src/python
linked by target "python_module_qgis__networkanalysis" in directory
C:/CodingX/QGIS/python
linked by target "python_module_qgis__core" in directory
linked by target "python_module_qgis__analysis" in directory
linked by target "python_module_qgis__gui" in directory
QWTPOLAR_INCLUDE_DIR
used as include directory in directory C:/CodingX/QGIS/src/app
QWTPOLAR_LIBRARY
linked by target "qgis_app" in directory C:/CodingX/QGIS/src/app
linked by target "qgis_maptoolselect" in directory
C:/CodingX/QGIS/tests/src/app
linked by target "qgis_apppythontest" in directory
linked by target "qgis_vectorlayersaveasdialogtest" in directory
linked by target "qgis_fieldcalculatortest" in directory
linked by target "qgis_maptoolidentifyaction" in directory
linked by target "qgis_attributetabletest" in directory
linked by target "qgis_measuretool" in directory
linked by target "qgis_qgisappclipboard" in directory
SPATIALINDEX_LIBRARY
linked by target "qgis_core" in directory C:/CodingX/QGIS/src/core
On 04/02/2017 00:06, Matthias Kuhn wrote:
> Hi Andrew,
> Compiling with Qt 5 (and therefore compiling master) on Windows is
> still very experimental. The libraries are not yet available on
> osgeo4w and I'm not sure if they are available elsewhere (QCA, QWT,
> QtWebKit, PyQt5-Python3 etc.).
> Depending on what you need, compile the release-2_18 branch with the
> dependencies on osgeo4w, wait a little longer until the dependencies
> become available (or use linux or mac or if you really want you can
> also try to compile all the dependencies yourself as well).
> Matthias
> On 03/02/2017 18:18, Andrew Gillett wrote:
>> Any particular version of QT? It turns out it can't be higher than QT
>> 5.5 because QTWebKit was removed in later versions. But QTScript is
>> not present in 5.5. Now I'm trying 5.3 but I get:
>> CMake Error at cmake/FindQCA.cmake:59 (message):
>> Could not find QCA
>> Call Stack (most recent call first):
>> CMakeLists.txt:292 (FIND_PACKAGE)
>> Went back to OSGeo4W setup, installed QCA-libs and QCA-devel - no
>> difference.
>> On 03/02/2017 14:16, Luigi Pirelli wrote:
>>> for master (eg. QGIS3.x) is a prerequisite
>>> Luigi Pirelli
>>> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
>>> * LinkedIn:https://www.linkedin.com/in/luigipirelli
>>> * Stackexchange:http://gis.stackexchange.com/users/19667/luigi-pirelli
>>> * GitHub:https://github.com/luipir
>>> * Mastering QGIS 2nd Edition:
>>> *https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>>> On 3 February 2017 at 14:12, Andrew Gillett<arganoid at pair.com> wrote:
>>>> I get the following error during the configure stage in CMake:
>>>> CMake Error at CMakeLists.txt:248 (FIND_PACKAGE):
>>>> By not providing "FindQt5Gui.cmake" in CMAKE_MODULE_PATH this project has
>>>> asked CMake to find a package configuration file provided by "Qt5Gui", but
>>>> CMake did not find one.
>>>> Could not find a package configuration file provided by "Qt5Gui" with any
>>>> of the following names:
>>>> Qt5GuiConfig.cmake
>>>> qt5gui-config.cmake
>>>> Add the installation prefix of "Qt5Gui" to CMAKE_PREFIX_PATH or set
>>>> "Qt5Gui_DIR" to a directory containing one of the above files. If
>>>> "Qt5Gui"
>>>> provides a separate development package or SDK, be sure it has been
>>>> installed.
>>>> QT5 is not mentioned in the docs as a prerequisite, am I meant to get it
>>>> fromwww.qt.io (installer wants me to create an account) or is it meant to
>>>> come from somewhere else?
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170206/6abeccfb/attachment-0001.html>
