[Qgis-developer] Building QGIS2.99 cloned from GitHub on Ubuntu 16.10 (yakkety) 64-bit Python
Jürgen E. Fischer jef at norbit.de
Thu Feb 9 00:50:19 PST 2017
Hi Gordon,
On Wed, 08. Feb 2017 at 18:01:52 -0500, gordon at shieldaig.com wrote:
> This is what I discovered.
> On Ubuntu 16.10 the following packages: `pyqt5-dev pyqt5-dev-tools
> pyqt5.qsci-dev` seem to be the Qt 5.7 version.
> I removed them and reinstalled to confirm.  Then I deleted the build
> folder and started over.
As a shortcut you can also build debian packages (see INSTALL). That will take
care of the dependencies (ie. complain about what's missing) and leave a build
directory in debian/build.   You could also interrupt the build once it's
setup.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170209/665f1ab2/attachment.sig>
