[Qgis-developer] EXT :Re: qgis 2.18
Smith, Dan [US] (MS)
Daniel.Smith5 at ngc.com
Thu Feb 16 10:20:03 PST 2017
So does that mean that you cant install and import tkinter and use it in a plugin or just that I should be using pyqt4? Because I was just looking for a way that I could run an gui that we had already created for another purpose from qgis but being able to still be able to pass in data from qgis and have access to all the iface variables etc.
-----Original Message-----
Sent: Wednesday, February 15, 2017 5:05 PM
To: Smith, Dan [US] (MS) <Daniel.Smith5 at ngc.com>
Cc: qgis-developer at lists.osgeo.org
Subject: EXT :Re: [Qgis-developer] qgis 2.18
Dear Dan,
QGIS uses Qt and pyQt (in python plugins).
You should install Qt4, pyQt4 and Python 2 for QGIS 2.x. The next 3.x QGIS release will use Qt5 and Python 3.
Regards
Zoltan
On Wed, 15 Feb 2017, Smith, Dan [US] (MS) wrote:
> Is it possible to run a python gui using tkinter from the qgis application as a plugin. It doesn't look like I am able to import Tkinter because it doesn't come with the python that's installed with qgis.
