[Qgis-developer] Improving QGIS integration in cartographic workfows
Vincent Schut schut at satelligence.com
Fri Feb 17 00:32:20 PST 2017
Just chiming in as a qgis-user: the best (imho) open source DTP software is
build with QT: scribus (https://www.scribus.net/). Afaik it does support
most things professional publishers need, such as CMYK workflows, high
quality PDF exports, etc. Might be worth taking a look at, or contacting
the devs about this, as they seem to have solved most of these problems?
Vincent.
On Fri, Feb 17, 2017 at 8:50 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > Unfortunately this is quite involved. At the moment QGIS is highly
> > tied into Qt's painter and printer framework. It's going to be very
> > difficult to change this and make a change like using another library
> > for exports. I think the most feasible approach would be to get the
> > changes we require implemented upstream in Qt itself. It's likely less
> > work, and also benefits other Qt projects too.
> The GDAL PDF writer creates PDF "at hand" and is able to create layered
> PDFs :
> http://gdal.org/frmt_pdf.html
> Currently one raster layer, one "annotation" layer for legend, and several
> vector layers, mostly due to the API constraints of the GDAL API.
> I'm not sure how feasible it would be (would require at least renumbering
> PDF objects and merging drawing instructions), but potentially you could
> render several layers into separate PDFs and then merge the PDFs into a
> single layered one
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170217/7dc53f52/attachment-0001.html>
