[Qgis-developer] color widget not updated after changing item color by python
Raymond Nijssen
r.nijssen at terglobo.nl
Tue Feb 28 00:14:41 PST 2017
Thanks Nyall! I would have never come up with a workaround like this.
Should this be fixed? Or is this "by design"? :)
Btw, the QgsComposerMap does not like this workaround, BUT also does not
need it because the color widgets seem to get updated anyway.
Raymond
On 28-02-17 06:27, Nyall Dawson wrote:
> On 27 February 2017 at 01:17, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
>> When changing the color of a composer item using python, the corresponding
>> color widget does not update to my new color.
>> For example, changing the label font color:
>> composerLabel.setFontColor(QColor(50,50,50,255))
>> After a redraw, the label's color in the map does change to my new value.
>> But after selecting it, the widget still shows a black (#000000) value. How
>> can I tell the gui to change as well? And shouldn't setFontColor function
>> tell the gui to change?
>> Hoping anyone can help.
> Hmm... seems only possible with a silly workaround:
> old_id = item.id()
> item.setId('a')
> item.setId(old_id)
> Nyall
