[Qgis-developer] Merge QGIS Resource Sharing Plugin into core
Paolo Cavallini cavallini at faunalia.it
Fri Jan 6 08:33:12 PST 2017
Il 06/01/2017 17:28, Alessandro Pasotti ha scritto:
> On Fri, Jan 6, 2017 at 5:20 PM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Hi,
>     This mainly means it is preinstalled (and enabled) out of the box
>     and there will updates will happen via the usual QGIS release schedule?
>     Or is there anything else to it?
> That should be all.
+1
we should also consider in the process if it is worth the while to port
to this also other resource sharing areas, namely Processing models etc.
Thanks Alessandro.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
