[Qgis-developer] Proposal - Change mIconProjectionEnable/Disable Icons
Alexandre Neto senhor.neto at gmail.com
Sun Jan 15 15:56:26 PST 2017
Proposal: for consistency, change the current mIconProjectionEnable and
mIconProjectionDisable Icons. These are the Icons next to the EPSG code
Rationale: While converting those icons from PNG to SVG, I could not
understand what they were, or try to represent. Besides, these buttons open
the CRS tab in project properties, which uses another Icon (CRS.svg). So,
for consistency and user's recognition, it would be better to use always
the same icon when we are referring to select a CRS.
My idea is to use the CRS.svg icon as a base to create a version for
enable/disable icons that look good at 16x16 pixels.
http://imgur.com/O7hKsmK
I would also replace the Icon in the capture coordinates plugin, which is
the same.
Any objections to this?
Alexandre Neto
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170115/c555d083/attachment.html>
