[Qgis-developer] Valid or invalid geom in PostGIS?
Mark Johnson
mj10777 at googlemail.com
Mon Jan 16 19:01:42 PST 2017
> thanks for your feedback. Shouldn't this be reported by ST_IsValid also?
Yes, it should.
SELECT
ST_GeomFromText('POLYGON((7 7, 77 77, 35 35,7 7))') AS bad_poly,
ST_IsValid(ST_GeomFromText('POLYGON((7 7, 77 77, 35 35,7 7))')) AS
bad_poly_valid,
ST_IsValidDetail(ST_GeomFromText('POLYGON((7 7, 77 77, 35 35,7 7))')) AS
bad_poly_geom,
ST_IsValidReason(ST_GeomFromText('POLYGON((7 7, 77 77, 35 35,7 7))')) AS
bad_poly_reason;
will report:
GEOS warning: Self-intersection at or near point 7 7
(as shown when called from spatialite in a terminal)
and as the result of ST_ValidReason: Self-intersection[7 7]
I cannot find a simple sample to reproduce the second error:
- Invalid number of points in LinearRing found 3 - must be 0 or >= 4
A simple sample that produces both errors at the same time
- could possibly show if the second error possibly interferes with the first
-- causing ST_IsValid to return TRUE, which should never happen
If you could supply the offending geometry in a text file (i.e. result of
'ST_AsText(geometry)'), then this could be checked.
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170117/5678e034/attachment.html>
