[Qgis-developer] QGIS 3 (Ubuntu 16.04)
G. Allegri giohappy at gmail.com
Sat Jan 21 13:07:28 PST 2017
I suggest you to use Qt Creator if you can. AFAIK it's the easier way to
develop and build QGIS. You will also have the benefit to design the UI
components visually, being Qt (Gui) stuff.
The docs provide some guidelines to setup Qt Creator:
https://www.qgis.org/en/site/getinvolved/development/qgisdevelopersguide/qtcreator.html
All the best,
Giovanni
Il 21 gen 2017 21:02, <gordon at shieldaig.com> ha scritto:
> Has anyone a QGIS toolchain for using g++ and Qt5.7 or Qt5.8 with Eclipse
> Oxygen - that they are willing to share?
> The documentation indicates how to build with CMake but does not indicate
> the preferred way to develop and/or test code.
> Is Qt Creator the preferred IDE?  Or can it be done with Eclipse?
> What is the preferred test environment?
> Any pointers would be appreciated.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170121/148583f2/attachment.html>
