[Qgis-developer] problem with ON INSERT TO ... DO INSTEAD postgres rules
Luca Lanteri lklanteri at gmail.com
Mon Jan 23 09:45:06 PST 2017
Hi Matthias,
thanks for your answer. Sorry but I missed your previous mail.
Now I've seen that in your example you used TRIGGERS to update your data,
instead in my case I use view RULES.
I try to add "RETURNING new" clause in the rules but it doesn't work.
I can try to change all my code and substitute RULES with TRIGGERS but I
still hope there is another way to maintain the possibility of using rules.
Is It possible that I'm just missing a simply solution because I don't know
well the using of RETURNING in postgres views?
thanks
Luca
2017-01-23 18:15 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Luca,
> this was a deliberate change to allow QGIS to directly use the newly
> inserted features (e.g. add child records to a newly created feature).
> To make the views compatible with this, all you need to do is add a
>     RETURN NEW;
> to the end of the insert function (I think). Have a look at the views
> which I linked in my response in the other thread.
> We could possibly add a flag to specify in which cases we need the new
> primary key and in which cases not.
> But I somehow suspect, that in the end we will need to specify this in
> some often-used code (e.g. add feature form) and in the end one will
> still be required to update all views and we have some half-baked
> pointless workaround code inside QGIS.
> Hope that helps for you!
> Matthias
> On 01/23/2017 04:19 PM, Luca Lanteri wrote:
> > Hi to all,
> > after a short disscussion in qgis user list I've opened this ticket [0],
> > because starting from QGIS 2.16 I can't insert new feature in postgres
> > views using rules. When I try to insert a new feature I have this error
> > [1]. All works fine with QGIS 2.14. The problem happens only with INSERT
> > rules. UPDATE and DELETE are ok.
> > I saw that for simple rules I can add a RETURNING * clause and all works
> > fine, but I have a lot of complex view that use many tables, so
> > RETURNING * clause doesn't work and compose the clause it's really hard.
> > Then I have some question:
> > 1) Is it really an issue or the problem is due to a new functionality of
> > QGIS ?
> > 2) In the first case, it could be considered a regression for it works
> > on QGIS 2.14 ?
> > 3) Is there a simple way to modify my views by adding a RETURNING clause
> > without specify all returning field (* doesn't work) ?
> > I love to know if it's a deliberate change or it's just a bug,so I can
> > choose if I have to modify all my views, in order to allow me to migrate
> > to QGIS 2.18.
> > Many thanks in advance
> > Regards
> > Luca
> > [0] https://hub.qgis.org/issues/16083
> > [1] Impossibile applicare le modifiche al vettore v_frane_pol_full
> > Errori: ERRORE: 1 geometria non aggiunta.
> > Errori della sorgente dati:
> > Errore PostGIS nell'aggiunta delle geometrie: ERROR: cannot perform
> > INSERT RETURNING on relation "v_frane_pol_full"
> > HINT: You need an unconditional ON INSERT DO INSTEAD rule with a
> > RETURNING clause.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170123/2e12119a/attachment-0001.html>
