[Qgis-developer] Exported SLD size or displacementX/Y are not reimported correctly due to mm/pixel ambiguity
Luigi Pirelli luipir at gmail.com
Wed Jan 25 07:21:14 PST 2017
Ha ok, now it's clear
I'll downgrade the issue to simple bug.
BTW this suggest that any export fix would check also import side to
maintain QGIS consistency.
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 25 January 2017 at 16:10, Andrea Aime <andrea.aime at geo-solutions.it> wrote:
> Hi Luigi,
> I don't think it's a regression but an incomplete fix, the qgis code still
> imports SLD
> assigning mm as units, while in SLD everything is in pixels unless otherwise
> stated.
> This needs to be fixed in all SLD import procedures (large-ish change).
> Before QGIS was wrongly exporting and wrongly importing, however the two
> errors were canceling each other out ;-)
> Cheers
> Andrea
> On Wed, Jan 25, 2017 at 3:49 PM, Luigi Pirelli <luipir at gmail.com> wrote:
>> Hi
>> I opened the following tiket
>> http://hub.qgis.org/issues/16112
>> a regression respect SLD fixies/compatibility with geoserver SLD.
>> Andrea, can you give a look?
>> Luigi Pirelli
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39  339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
