[Qgis-developer] QGIS Server - SSL handshake failed for cascading WMS
G. Allegri giohappy at gmail.com
Fri Jan 27 09:19:00 PST 2017
Network management of QGIS Server is definetely week. We alse faced this
issue and I thought to bypass it setting a proxy... but it isn't possibile
to set a proxy for QGIS Server to use (as you can do in QGIS).
So neither SSL nor a proxy can be configured. I suggest to add this to the
ongoing server refactoring...
giovanni
Il 27 gen 2017 16:48, "Neumann, Andreas" <a.neumann at carto.net> ha scritto:
> Some more information on my server:
> Linux CentOS7
> qt 4.8.5
> The server only allows tls connections, no SSLv2/3 or such vulnerable
> stuff. Perhaps qt is too old to properly support tls ciphers?
> Can I add an SSL "do not check exception" for specific connections of QGIS
> server?
> If yes - how would I configure that for QGIS server?
> Thanks for any hints,
> Andreas
> On 2017-01-27 16:31, Neumann, Andreas wrote:
> Hi,
> I want to use a cascading WMS in QGIS server. I know it is not ideal,
> perfomance wise, but it would be only for printing.
> Problem is that the WMS uses https and QGIS server can't connect. The QGIS
> server log shows a connect error:
> Download of capabilities failed: SSL handshake failed
> curl or wget on the same server works fine with the same ssl connection.
> Anyone knows how I can overcome this SSL handshake issue? Do I need to set
> up a separate certificat chain for QGIS server? I hope not ...
> Andreas
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170127/bf13b22f/attachment.html>
