[QGIS-Developer] Regular vs spatialite sqlite database
enrico chiaradia enrico.chiaradia at yahoo.it
Mon Jul 24 02:32:17 PDT 2017
Dear List,
I’m developing a python qgis based application the creates several new
empty layers that will be filled by the user using already existing qgis
editing tools and some tables of parameters that I will provide through
the plugin. I’m dealing with the choose of the best file format to store
this information. The ideal file format should be:
1) completely supported by qgis (I/O, editing and simple db function as
joining)
2) store the data in a single file on the hard disk (server connection
feature is not required at the moment)
3) manage both geometry and simple tables of data (i.e. with not
geometry fields)
4) fast I/O
5) the generated file must be of smallest size as the user will be able
to deliver it in the faster manner or creates multiple copies of it.
My first implementation used ESRI shapefile format that obviously didn’t
respect requirement n. 2 but generated files are very small (5) and
creation process is very fast (4). On the contrary, the creation of
simple DBF file is not so straightforward in pyqgis (I used ogr) and DBF
is very limited itself.
My second implementation uses Spatialite DB but I found it surprisingly
slower than shapefile and the file created is very big (more than 5 MB)
also for empty tables. Requirements number 2 and 3 are successfully
satisfied.
In my last implementation, I used a mixed approach, creating both
shapefiles to store geometries and regular sqlite db to store simple
tables. That is fast and space saving but it generates too much files.
Currently, I'm looking to a definitely solution to the problem. My last
idea is to store all data in a regular sqlite file (not spatialite) but
I didn’t find any example about it.
Regular sqlite DB seems to be fully supported by QGIS and its file is
lighter than Spatialite. Before starting the implementation of this
solution. I’d like to ask you which disadvantages I might encounter and
if someone has experiences with the use of regular sqlite DB for curstom
qgis application.
Thank you for your time,
enrico
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170724/d4572f00/attachment-0001.html>
More information about the QGIS-Developer mailing list
