[QGIS-Developer] Use of QtWebKit in plugin
Niels Kjøller Hansen niels.k.h at gmail.com
Mon Jun 19 05:29:52 PDT 2017
Hi Jürgen
2017-06-19 14:18 GMT+02:00 Jürgen E. Fischer <jef at norbit.de>:
> Hi Niels,
> On Mon, 19. Jun 2017 at 04:48:07 -0700, kjoller wrote:
> > I have been trying to fix a bug in the "Kortforsyningen" plugin for QGIS,
> > which exists in Ubuntu 17.04 and Debian stretch (and probably other newer
> > debian based systems), due to QtWebKit not being included in PyQt4
> It should be included as internal bindings in python-qgis for unstable,
> stretch, yakkety and zesty.
> /usr/lib/python2.7/dist-packages/PyQt4/QtWebKit.(i386|x86_64)-linux-gnu.so
You are correct that the QtWebkit itself is included, but as far as I can
se, the "definition"-file for pyuic4 is not, as far as I can tell.
/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/qtwebkit.py
It is a simple file, and stripped for comments it looks like this:
pluginType = MODULE
def moduleInformation():
    return "PyQt4.QtWebKit", ("QWebView", )
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170619/d59b1b9c/attachment.html>
More information about the QGIS-Developer mailing list
