[Qgis-developer] OGR Buffer fails in Processing
Paolo Cavallini cavallini at faunalia.it
Thu Mar 2 14:34:17 PST 2017
Hi all,
a simple buffer fails if applied to a PostGIS layer:
Algorithm Buffer vectors starting...
GDAL command:
ogr2ogr
"/tmp/processingf5bab9b07d834e229b9dd70899b8face/971076e5d374495280a95f7adf2ec92a/OUTPUTLAYER.shp"
"PG:dbname='corso' host=localhost port=5432 user='utente'
password='utente' sslmode=disable" public.fiumi -dialect sqlite -sql
"SELECT ST_Buffer( geometry , 100 ),* FROM 'public.fiumi' "
GDAL command output:
Warning 1: layer names ignored in combination with -sql.
ERROR 1: In ExecuteSQL(): sqlite3_prepare(SELECT ST_Buffer( geometry ,
100 ),* FROM 'public.fiumi' ):
no such column: geometry
Converting outputs
Caricamento layer
The following layers were not correctly generated.
Buffer
You can check the log messages to find more information about the
execution of the algorithm
Whereas it runs fine when applied to a shapefile.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
