[Qgis-developer] [Qgis-user] QGIS loaded millions of entries
Nathan Woodrow madmanwoo at gmail.com
Sat Mar 4 00:25:36 PST 2017
Hmm are you sure we don't do this already?
I suspect we do. Each provider can handle the sorting, giving to it by
QgsFeatureRequest, and hand the results back to the caller.  I thought the
attribute table was already implemented this way.
Regards,
Nathan
On Sat, Mar 4, 2017 at 6:03 PM, Tobias Wendorff <
tobias.wendorff at tu-dortmund.de> wrote:
> Am Sa, 4.03.2017, 08:34 schrieb Alessandro Pasotti:
> > Yes, that would be a strategy, but you might run into problem with
> > sorting and filtering if the data provider does not support for it.
> All database-like formats, even Shapefile's DBF, support sorting
> on database level. I've never understood, why some applications
> download the whole content first and
> Microsoft Access is such a "problem". Some days ago, it has downloaded
> 700 MB of data from the database to figure out "first" and "min/max".
> Access has a "pass-through" function for this to make it directly
> work on database level, but it's somehow hard to handle.
> But you're right. For things like sorting in calculation, there
> has to be a different solution, like threaded or staged or using
> "processing" toolbar only.
> My system can't even handle to download 3 * 10^6 attributes :(
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170304/16ccd8a9/attachment-0001.html>
