[Qgis-developer] PyQgsServerTest :: test_wms_getprint_srs disabled
Alessandro Pasotti apasotti at gmail.com
Mon Mar 6 23:16:43 PST 2017
On Mon, Mar 6, 2017 at 5:30 PM, Paul Blottiere <blottiere.paul at gmail.com>
wrote:
> Hi Alessandro,
> can you please have a look?
> I'm afraid this failure is not a problem in the test itself but a symptom
> of more serious issue: the map is completely missing from the generated
> print.
> FYI, the same test also fails on 2.14 as discussed on the following commit:
> I took a look but I cannot reproduce the failing test
> test_wms_getprint_srs.
> Actually, I have tested it within the next environment without issues:
> - master on Debian
> - release-2_14 on Ubuntu.
> Can anyone confirm?
> Paul
Paul,
Thanks for looking into this, I'll do some local testing shortly, do you
have clue if the multi-threading rendering could be the root cause of this
issue?
A s a side note, I would recommend to refactor the server test and split it
in smaller dedicated tests for the different services.
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170307/e2571786/attachment-0001.html>
