[Qgis-developer] Changing behaviour of "show selected features" mode for attribute table
Nathan Woodrow madmanwoo at gmail.com
Mon Mar 6 23:46:11 PST 2017
Yeah I'm not really ok with a empty table as the default.  I understand the
point but users are going freak at that.
One option might be to ask users what they want when a table is first
opened for the first time.  E.g what default mode would you like with some
notes on each.  This is only asked once and never again but gives the user
the choice.
On Tue, 7 Mar 2017 5:43 pm Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Thanks for the precision.
> Then
> +1 for showing nothing when no selection
> +0 for "show only selected" as default mode.
> Le mar. 7 mars 2017 à 08:30, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
> On 7 March 2017 at 17:23, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> > I'm a bit confused here.
> > At the moment, there is a global option for attribute table widget "show
> > only selected".
> > If you choose this option and have a selection, you won't have any mean
> to
> > show all the layer unless you deselect and reopen the attribute table
> (hence
> > showing all). In other words, switching between show all and show
> selected
> > only has no effect and shows only selected features.
> > Does your work will fix this i.e. really show all features?
> In current master and 2.18 branch if you set the attribute table to
> show only selected, and then open the table and change the filter in
> the bottom left to "show all", then ALL features will be loaded
> (regardless of the current/original selection)
> Nyall
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170307/116812ad/attachment.html>
