[Qgis-developer] 3.0 Documentation and branching
Alexandre Neto senhor.neto at gmail.com
Tue Mar 7 02:21:00 PST 2017
Totally agree with Harrissou. A good description in the commit with the
rigth tags  should be enough.
Alex Neto
A ter, 7/03/2017, 10:06, DelazJ <delazj at gmail.com> escreveu:
> Hi,
> 2017-03-07 5:58 GMT+01:00 Nyall Dawson <nyall.dawson at gmail.com>:
> I think a better solution is to hook into the current
> [FEATURE]/[NEEDS-DOCS] hooks which auto-open issues on the
> documentation repo. We could *require* that all developers who push a
> new feature commit have to post on the corresponding documentation
> auto-opened issue with at least very rough notes about how the feature
> is supposed to work. The documentation team could then polish these
> up, add screenshots, etc (and merge when the timing is right for the
> team). This would also keep things as easy as possible for devs so
> that they (*cough*... i mean me *cough*) have no excuse not to do it!
> You are right, Nyall.
> However, I do not think that they later need to add information in the
> auto-opened issue in Doc repository. By default the generated issue is
> populated with all the information in the commit. So a really descriptive
> commit to QGIS repository with those tags should be enough. There are some
> very good (from a doc writer pov of course) commits where you only need to
> find the right place in the doc and copy paste the description with minor
> adjustments. Unfortunately, they are currently far from being the majority.
> On the other side, there still are many with simply the title (which
> sometimes can be helpful) or do use a dev language (too much cryptic?).
> Also note that a verbose commit benefits to the Changelog team, when time
> comes....
> Harrissou
> Nyall
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170307/df26b1bd/attachment.html>
