[Qgis-developer] New branch for 3.x documentation (master_3x)
Alexandre Neto senhor.neto at gmail.com
Wed Mar 8 02:17:02 PST 2017
Hi Mathias,
Having two babies in the house, I'm all for avoiding sleepless nights!
Not sure I followed your suggestion. AFAIK, The "master" branch (future
release-2_18) is already the default branch. And our plan was to keep a
close eye on that branch and continuously forward port everything from
master to master_3x, to avoid that single "big bang".
Maybe I'm not understanding your suggestion. If you don't mind, I will ping
you on gitter.
Alexandre Neto
A qua, 8/03/2017, 07:30, Matthias Kuhn <matthias at opengis.ch> escreveu:
Hi all,
Nice move!
I have a minor note on the setup.
"master_3x" will be merged into "master"* sounds like a plan, but I guess
in reality someone will spend days trying to figure out how to solve those
damned conflicts. I would strongly suggest against merging production
branches as this leads to a single "big bang" with interleaved effects of
documentation commits that have already been forward ported and missing
ones.
Instead I would propose to follow the branching schema of QGIS. On github
you can define the "default branch" in the repository settings to
release-2_18, so pull requests will be opened against this branch by
default at the moment.
Just my 2c, maybe it helps to avoid some sleepless nights if this adjusted
right now ;)
Matthias
On 08/03/2017 02:32, Alexandre Neto wrote:
Hello All,
As a result of a long discussion around how to contribute with
documentation for 3.x new features [0]
<https://lists.osgeo.org/pipermail/qgis-developer/2017-March/047346.html>,
we decided to create a master_3x branch [1]
<https://github.com/qgis/QGIS-Documentation/tree/master_3x>.
>From now on, all new features landing on QGIS 2.99 should be documented in
the "master_3x" branch.
All new documentation and improvements as we go through the latest releases
issues (2.16 [2]
<https://github.com/qgis/QGIS-Documentation/issues?q=is%3Aopen+is%3Aissue+milestone%3A%22QGIS+2.16%22>
and 2.18 [3]) should still be worked on the master branch. When it makes
sense, the documentation team will do his best to "forward port" them to
master_3x branch.
After 2.18 release as LTR (June?) and consequent release of 2.18
documentation, "master_3x" will be merged into "master" and all should go
back to normal. That is, all contributions can be done in the "master"
branch.
To help us document the all the new features, we kindly ask all developers
to add the [FEATURE] and [NEED-DOCS] tags in their commits and provide some
simple guidance on how to use the new features in the commit message.
Thanks
Alexandre Neto
[0] -
[1] - https://github.com/qgis/QGIS-Documentation/tree/master_3x
[2] -
[3] -
https://github.com/qgis/QGIS-Documentation/issues?q=is%3Aopen+is%3Aissue+milestone%3A%22QGIS+2.18%22
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
Qgis-developer mailing listQgis-developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170308/97359776/attachment-0001.html>
